Next Question: L/R Fuel Rail
Hi,
When looking at my fuel system tonight I realized my stock fuel and supply lines have a crimp on rubber hose. I took out the fender liner thinking I would find a steel line with a threaded fitting to tie into. That's not the case so how do you tie the L/R fuel rail into the stock supply lines? asnybody? I bought the fuel rail off a fellow lister and there was no instructions so I assumed it would be pretty straight forward. Not so. Help!
Lanny
Lanny
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
The Lindsey kit comes with a compression fitting that fits the stock fuel line – if yours is a used kit it might not have that. Lindsey sells those seperatly.
