So pissed off right now! HELP!!!!
Pumice King
So I am installing a Schnell Shift Kit this afternoon. Easy job, right? Well, for the most part that held true, until......The old linkage won't come away from the selector shaft that goes into the transmission itself! Each time I try to pry it off I just wind up shifting gears.....Has anyone had the same experience?? How do I get this damn thing off?!?!
TIA
Ryan - so pissed.
![soapbox](https://rennlist.com/forums/graemlins/soapbox.gif)
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
TIA
Ryan - so pissed.
Make sure that bolt with the saftey wire is completly removed. It has a taper at the end, and losinging it isn't enough.
If it's still stuck, I'd shift it into a gear that puts it forward, then tap on it with a hammer a little bit.
It should slide right off.
Pumice King
Thanks for the replies, I ended up running out of daylight, so I just sprayed some penetrant on it and I guess I will give it another go tomorrow...Cant't wait..
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
