How Much HP Should There Be?
Old 01-24-2007, 12:55 PM
RolexNJ
RolexNJ's Avatar
Originally Posted by MPD47
Jeff, no, stock engine other than turbo/managment/MAF/injectors is what he means.
You are correct, at that point ST had the VR Stage 3, and lots of Magical Pixey Dust too. And let's not forget, this is an engine that has a stock bottom end for years too. Fact, no BS. Then again, he is known for pushing the envelope, and running high boost levels. And yes Hos, the injectors were 72 lb.
Old 01-24-2007, 12:58 PM
hosrom_951
UAE Rennlist Ambassador
hosrom_951's Avatar
Wonder if the Magical Pixey Dust had anything to do with the monkeys group buy
Old 01-24-2007, 12:59 PM
Dr. Dynamics
Dr. Dynamics's Avatar
Sounds like Juancho's car
"He dicho nombre yo?"
Old 01-24-2007, 01:04 PM
Dr. Dynamics
Forgot to add:
72lb injectors
VR Wasted Spark
What recomendations are there to run 400rwhp w/ pump gas?
We'll have the dyno #s shortly after the intercooler arrives
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
Originally Posted by Porsche-O-Phile
Isn't the AFR of 12.0 a bit rich?
No.
If anything its a bit lean for pump gas and 21psi of boost.
Rogue
RolexNJ
RolexNJ's Avatar
Originally Posted by hosrom_951
Wonder if the Magical Pixey Dust had anything to do with the monkeys group buy.
Easy dude, I have a lot of Magical Pixy Dust from both VR and Chris White. And I will guarantee it will make my car perform very, very well. Hey, once I had John's stuff on my old car, it was a night and day difference with respect to every characteristic, so there! Let alone his Wasted Spark.
Mike: With the bit more mods he has, he should be at least where you were at. Thats my two pennies.
Old 01-24-2007, 01:11 PM
Dr. Dynamics
Rogue
Just to correct...it was racing fuel @ 21 psi
EGTs were at 800C in the infield and 850-875C on the straightaway (basically 3rd and 4th gear)
Old 01-24-2007, 01:20 PM
fast951
fast951's Avatar
Look at the dyno charts, they are posted on the web site as sent by customers (no BS factor!!!).
For each 1psi boost, you should gain approx 12-15rwhp. Simple math.
Head work, intake, intercooler all change the outcome (some good, some bad).
ST did a 407rwhp at high boost, but he had a badly made test-pipe creating LOTS of backpressure.
DR Dynamics, 21psi boost on pump gas is NOT ADVISED - on this car, 400rwhp on pump gas is not happening!!!
Juan can read EGTs on his car. The timing used is for safe boost and acceptable EGTs. The iea of running 20+psi on pump gas requires timing retard, which will cause the EGTs to rise where it's no longer safe. Those doing a dyno run at high boost, or a quick burst on the street with timing badly retarded will not last a 20min session on the track as the high EGTs will hurt them.
People spend lots of money on their cars, why not use better octane (or water injection) when they are pushing it? Simple insurance!!!!
When on full race gas, make sure to use the race maps - externally selectable. Also, shoot for 11.8:1 AFR.. It will give you the largest area under the torque curve.
John
Email
www.vitesseracing.com
Old 01-24-2007, 01:22 PM
Rogue_Ant
Rogue_Ant's Avatar
Originally Posted by Dr. Dynamics
Rogue
Good, I wouldn't want to see someone blow an engine because of a lean condition.
Rogue
Old 01-24-2007, 01:47 PM
Porsche-O-Phile
Porsche-O-Phile's Avatar
Did it have the "Mexican Jumping Bean" air shock suspension package for maximum pimpage too?
Old 01-24-2007, 03:31 PM
juanchovidal
juanchovidal's Avatar
****!!!! you got me, I hope you didn't catch your girl "jumping like the bean" on top of me.
Old 01-24-2007, 04:24 PM
Dr. Dynamics
John, I was thinking more on the line of making the engine breathe more efficiently...probably thinking on the Garrett side.
I was wondering if somebody has had experience with swapping to these (mostly thinking on the hotside)
BTW...do you have available the turbo map for the Stage III? just to know were the engine is.
Old 01-24-2007, 04:31 PM
Porschefile
Porschefile's Avatar
With 21psi on something higher than pump (additives or race gas), you should see 400+whp depending on your fuel system (injector size), and hopefully assuming you aren't using a stock cam.
Old 01-24-2007, 04:49 PM
reno808
reno808's Avatar
iF WOULD spend all that money and time and the only made 350 to the wheel i would think somthing would be wrong and reconsider somethings
Old 01-24-2007, 05:04 PM
juanchovidal
We are assuming 21psi.
We have a vitesse wg and the profec B is on hight boost on the max.
On the gauge is +/- 1.5 bar (graddy)
Quick Reply: How Much HP Should There Be?
