Rear rim width
#46
Originally Posted by MPD47
You guys really dont need that much tire. Afterall the 928, which happens to be the best car ever, can fit that stock. I wish I had a 928. Randy is always telling me how awesome they are, and I've got 4 less cylinders than him That's why I bought an LS1.
The King has spoken - all hail the wisdom of the King!
#48
Hey Rob did you speak to Chris re that white car with the wide steel guards? I'd be curious as how difficult this was to do and what sort of $$$ we're talking. I'm guessing it's not cheap. You would probably need to do a major re-spray too wouldn't you think?
#49
#50
Ok I'll ask him. I think it sounds like the '89 could get 305's in there with a little work. This is what I'm aiming for. I'll run the engine in on the 285's and see what it's like. One of the best things about my suspension is the way it puts down the power. It is very hard to get wheelspin unless you try for it. I could probably put 295's on my rims now or get them widened or get new ones. I'll see.
#51
If you want some traction, throw some ~275 or 285 BFG g-force t/a drag radials on! Those things grip hard for being (barely) street legal. Handling sucks though. I'd vote for some Kumho MX's or Falken Rt615's. MPSC's, judging by what I've experienced of them, seem to be very picky about operating in a specific temperature range. For the street, IMO the MPSC's are overkill for the price. Those things really deserve track usage more than just the occasional spirited drive on the street. Otherwise, just go all out and run some Hoosier R6's on your daily, but make sure to do some warm up laps around the neighborhood before leaving.
#52
#53
Thanks for advice Rolex CCW were very quick to respond and say they are happy to fit 18x10's on the rear without worrying about which tire to fit (which is good) Whats the max tire width I could fit on a 10" wide rim? 295?? and what profile would I need / could I fit with 18" wheels? I would like to go at least one profile over the norm to extend my gear ratio's a little... if it will fit without scrubbing under HARD abuse!
Ben
Ben
#54
1 Post
A 295 needs a 11 inch wheel to work correctly. Porsche coincidently shares the same thought. 285 is ideal for 10 inch.
Poor traction has a lot to do with the outdated (by todays standard) 951 rear suspension or using old technology (Bilstein Cup) as a upgrade. Shock science has come a long way and todays upper end suspension manufacturers are able to run almost insane spring rates with almost stock ride comfort.
#55
Originally Posted by pole position
A 295 needs a 11 inch wheel to work correctly. Porsche coincidentally shares the same thought. 285 is ideal for 10 inch.
I know you guys aren't that keen on Toyo's but they're way superior to the MPSC's for my usage. No contest. As Travis said they (Mich.) seem to be temperamental and take too long to get up to temp. The Toyo R888's aren't in the U.S. yet, but I bet when they do land they will quickly gain momentum as a priority choice for racers.
#56
Ben: You are welcome, glad to help anytime my friend. As I said, contact CCW for "exact" wheel fitment measurements and specs that are just for "your" car. I would trust a company like them or Fikse with their proven expertise.
#57
Yup, that all makes sense. Bigger is better (up to a point of course) but 305's would be a nice way to go.
#58
Ben
Ben
I can't wait to see it
#59
Originally Posted by Diver944
Still shooting to be the first UK 951 over 200mph then Ben. I can't wait to see it
#60
Don't worry I have no plans to get near the double ton, my engine won't be revving as high as Bens and I have enough rims with track tyres on that are already slightly lower in profile. I don't want to be buying a high profile set too
