Timing...????
So I've diagnosed my problem and am replacing the head gasket. However in the process of pulling the head the timing belt has to come off as everyone knows. Does anyone have a detailed write-up, link, or any advice on how to get the timing right? Thanks...
To time the cam sprocket, if you have the cover on look through the little hole and theres a pointer on the cover that lines up with a groove on the sprocket. Then for the crank theres a cut out down by the starter on the bell housing and a mark on the flywheel you center in the cut out.
