Is this damaged or manufacturer standard
I beleive it's called the bearing seal. All other parts inside the CV joint have no wear on them (including the bearings). I'm not sure what to make of these marks. I'm leaning towards replacing it.
Originally Posted by Bonestock951S
What will cause that type of damage?
-Darwin
-Darwin
Typical wear for a aged CV. It will continue to gall until it clacks. Some people swap axles from side to side for a few more miles of use. The CV's are easy to change but they are messy. Better to buy the full axle assembled IMO unless you only find one CV that's damaged
There are a few solutions to this.
1. Replace the part itself (hopefully Lart can help me out here)
2. Replace the Axle ($300~)
3. Replace the entire CVjoint (porsche quoted me @ $108.00)
Originally Posted by Ballistic
Agreed. I'm guessing a torn CVboot and age caused this problem. Friction is never good.
and save yourself $468 for 2 of them...tough call huh? tear them up, turn them in for new ones. Even if you don't use the actual axle in the set the CV's are interchangeable between the NA and Turbo and very easy to swap to your turbo axle, at least for 83 to 86.
http://www.partsamerica.com/ProductD...pe=945&ptset=A
Or you could always go with one of these for already assembled with lifetime warranty
Originally Posted by JET951
thats part of your CV joint, and its rooted. get new ones, if thats not making noise yet, it will soon.
the ball bearings never really wear, its always the casings
Originally Posted by lart951
I have the axles a set of 2 for $ 99.00 shipped to your door.
