Deja vu, Tech's input needed
Basic Sponsor
Well, 3 years later after my catastrophic engine disaster, I was changing my oil today and there it was the nightmare of every 951 owner a piece of metal was stuck to the magnet in the oil plug. Check it out it is not hard but kind of soft, I can bend it with my fingers, can someone tell me the possible scenarios where this piece of metal might have come from? Ring? Rod bearing, main bearing? Also I changed my plugs do they look like if they are burning oil to you guys?
Tia
Lart
Tia
Lart
Basic Sponsor
Originally Posted by mwc951
Looks like a spark plug sealing ring
I thought the same thing but how it could have traveled all the way to the oil pan?
When the thrust bearing gets to be completely gone the crank counterbalancing weights can rub the main bearing girdle and make a chip like that. Check the thrust of the crankshaft to be sure. I think the cap is made of cast iron which would be magnetic, and I cant think of many other things that size that would be. Definately not a spark plug seal if it is magnetic.
Basic Sponsor
I didnt think of the valve stem seal, but that is more likely than what I suggested for sure. The rod bearings would be toast by that point as well, and you would notice other problems.
What is your max rpm? Maybe time to upgrade the valvtrain.
Basic Sponsor
