8-valve, 500+ hp 944 Turbo - Excellence #82 Dec 1998
#61
No. Wrong issue too. If it was sold, that was Bob Howard's car. Long story and problems behind that car. But that's not the car Todd started this thread on.
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
#62
I decided to get off my butt and dig out the Excellence collection. I found the issue and now I remember this article. It's red with Fikse wheels. Some pretty impressive numbers are listed in the article. Anyone know where the car is today? Does Mr. Gillies still have it? The article also mentions numerous track days. I'm going to do a search on the web and see if I can find some lap times.
#63
I did a little search and found this:
http://www.968.net/modifications/powerhaus_turbo.htm
It appears the engine in the Excellence magazine didn't last long.![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
Take a look at the dyno comparison. Even though the new 3.0 turbo made less peak power it makes much more all over.
#64
#65
It appears the engine in the Excellence magazine didn't last long. ![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
The PowerHaus built 2.8L engine with stock injectors ran very reliably for over 60K miles, and this included lots of track days. This is the engine in the Excellence article
It blew-up "after installing the Huntley Level-IV+ parts: ARC-II, injectors, and associated nonsense" (according to http://www.968.net/modifications/powerhaus_turbo.htm).
In fact, the car owner went back to PowerHaus to get have a 3.0L turbo engine built after the 2.8L grenaded.
Karl.
#66
Originally Posted by Porschefile
To convert lb/hr units into CC's, multiply by 10.5: 37# x 10.5 = 388.5. I said 370cc to be a bit conservative as there can always be differences in flow from an injector to injector. The stock injectors are rated at the stock fuel pressure of 2.5 bar AFAIK. Running 3 bar will increase the flow capability of the injectors a bit. Here is an official source if you want to double check my math
RC Engineering
RC Engineering
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
#67
You're a funny guy Rolex, equating my comments with Danno as if that should automatically invalidate anything I say. RC Engineering is a large and reputable company. The conversion factor may be off by a small amount, however it's close enough. The stock injectors would have to flow a SIGNIFICANT amount more to be physically capable of flowing the volume of fuel required to make 400+whp on a 951 running the typical ~3bar of fuel pressure. The fact remains, there is no substantiating evidence to suggest that it would be possible on stock injectors.
#68
#69
Originally Posted by RolexNJ
I would call RC and ask them about that calculator. Last time I called and went over a flow rate, they told me that their Internet calculator was off. This was last year though. I'm sure there are others you can use, besides this one that Danno used and everyone knows from him.
Since nobody else took you up on the verification challenge and these are very simple formulas, I tested RC Engineering’s calculator out and found a couple insignificant errors. Also, I have to take their bsfc recommendations at face value, but the end-result seems to correspond to my previous energy calculations.
The calculator does not take into account fractions of fuel pressure (in psi). Only whole numbers can be used (a random error between 0% and 3%).
The unit conversion factor of 10.5 for gasoline flow between lb/hr and cc/min is slightly off and should be 1 lb/hr = 453.6 g/hr = 7.56 g/min = 10.23 cc/min with the assumption that the specific gravity of gasoline is 0.739 g/cc (a systematic error of 2.6%).
Referring to fuel pressure as “System fuel pressure @ fuel rail” is only valid for a N/A car at WOT. A more correct term could be “Pressure drop across injector in- and outlet”, which a typical fuel pressure regulator keeps constant.
It is worthwhile noting that they are only referring to bhp or flywheel HP.
A frequently occurring (minor) flow mislabeling comes from the fact that injector retailers use a flow-test fluid with slightly different properties than gasoline. So for example an injector that flows 72 lb/hr of gasoline flows 75 lb/hr of test fluid, see Racetronix .
All in all, after going through it in detail, I find RC Engineering’s calculator fully adequate for sizing injectors.
Laust
#71
Originally Posted by mtnman82
I don't know how you guys can concentrate after rocket makes a post (drooooooooooollll!!!!). Who is that most beautiful woman in your avatar, rocket???
OOOOO double d boobies
#72
Originally Posted by Karl Glynn
Nope.
Karl.
Karl.
#73
Porschefile, you really are a touchy and emotional kind of guy. Anything anyone says that you in your 'experience' disagree with must be an attack on your personal integrity. You really need to relax. Have you built any 951's that hang with Rolex's? His 'experience' is in THIS car..how many modified 951's have you built? If you don't choose to believe dyno charts, that is your choice. If you don't choose to believe people posting with no objective other than to inform others, that is also your choice. But if it really takes you 8 years to build ONE car....seriously, give those with experience the benefit of the doubt.
So the powerhaus 2.8 on stock injectors is impossible. My car is impossible (80k miles in this impossible build). Rolex is smearing you to promote his love of fuzzy wuzzy bears. It really doesn't matter how many people tell you their actual experience differs from your mathmatics does it? You must be some kind of misunderstood genius.
Ok, I'll bite...what is your experience in the 951 line? How many heavily modified motors have you built and tuned yourself? I mean seriously, if you are going to poo-poo on everyone who disagrees with you...lets hear your resume. Post some of the dyno charts from engines you have built and tuned yourself or for the love of god pipe down and admit to yourself that you might be wrong. Is it really that hard for you? Do you honestly think you are going to convince anyone that you know more than powerhaus? Post up the proof of your knowledge and I might lean towards believing the car in my garage hasn't really run so well for so long.
Wanna race for that beer now? Oh and by the way...anything you build...don't ever put it up against anything Rolex is driving.
Bill
89 951
Bill
89 951
#74
Hey Solo, I have that answer. Grahm let Huntley convince him that there was more power to be had by installing the parts mentioned here. He went back to ask David at Powerhaus what he thought. He said don't do it or you'll be back for a rebuild. He did it anyway and it grenaded as David said it would so he went back for the 3.0 liter build. I was there through most all of both builds as my car was in and out often then. You should have seen how badly it blew from Huntley's products. Hence Derek has since left the industry.
#75
Bill
89 951
Bill
89 951
why did you bring Rolex into this either, i dont want to disrespect Rolex but i dont think he builds 951 engines, he relies on advice from others as to which way to go. so really the experience is somewhat left to others in the game.
