The Complete Venturi Update Kit
Originally Posted by toddk911
When I said they replaced the other hoses, I meant the original hoses while they had the intake off. They did not ADD any hoses like in the kit.
There's the confusion.
The kit does not really add anything. It merely replaces existing hoses. The only difference is the AOS line.
If your mechanic removed the hard venturi line, he had to use these hose. If he did not, what's the point? It's so much more simple and clean without that damned thing in there.
Originally Posted by PorscheDoc
I'd love to see a picture with your intake off. It's been awhile since I have really looked at the venturi assembly, but I don't see how that is possible. Porsche updated to these hoses in 89 so they could get rid of the venturi mess. If it was as easy as capping a port, you'd think they would have done it.
ok, am more than halfway through this on my 86. have the 3 hoses as from lindsey. The only thing that I dont have now is what I BELIEVE is being discussed here. In all of the documentation up to this point, the hole in the J-boot that connects through the hard lines (now removed) to the Air Oil Separator, is plugged; and there's no mention of what happens with the AOS.
1) what happens if it's left open to air?
2) will oil spew out?
3) can I simply run some sort of patch hose from the AOS to the J-boot?
4) what's the purpose of the check valve as mentioned above?
Thanks,
Ian
Thanks,
Ian
Thanks,
Ian
Thanks,
Ian
Porsche doc, sounds good, the next question then is does that hose with the check valve actually run all the way to the J boot or is it simply a length of hose with a closed end and the valve? if it does go all the way to the boot, how do you plumb it in with the original male end that was on the hose connecting the original hard pipe to the J-boot?
Thanks,
Ian
Thanks,
Ian
Thanks,
Ian
Thanks,
Ian
I replaced my vac lines last winter with a few other things on my '89 turbo.
Yep the valve is stock. Short 90 deg. hose off the AOS with the valve before it tee's into the metal pipe. I ended up leaving the 90 with the valve in and went male to male with a new hose to the J boot, not because i know what i'm doing but because i didn't know what the valve did.
A couple of pics from last years project and one from today.
You can see the valve going off to the left of the 90 deg. hose.
TRB0 GUY
It's certainly possible to bypass the CV without removing the intake, but you sure can't do the full venturi delete with it still on. I think that's the confusion. I bypassed the CV last year in my red 951, but since I have the manifold off the silver project car, I'm going to do the delete kit.
I hate the mess under the intake manifold.
I have the new hose installed on my engine, which is sitting on the stand. I will pull the intake and take a picture of it all....
My theory is under hard boost, the valve opens and allows outside air into the system, instead of sucking oil vapor from the crankcase, and causing excessive oil to be introduced to the intake stream. When the boost pressure drops, then it shuts and feeds off the crankcase again.
-Jeff
Originally Posted by ivai
PorscheDoc, this makes sense to me.. but wouldn't there need to be some sort of filter on the little checkvalve to prevent foreign material from entering the turbo/engine? Are you able to tell if it has such a thing?
-Jeff
-Jeff
Any chance you took pictures? I have all this stuff out in the open so I want to do it, if I can figure out exactly what to do.
On somewhat the same note: do you have to buy all the official porsche lines or can you run some tubing in their place? Looks like the one with the valve can't be cheaped out on, but what about the rest? Anything special about the porsche lines?
