Periodic start issues
I never notice, anyway
I'm having problems with the car wanting to start only some of the time. Sometimes it starts just perfectly. Other times, it just cranks and cranks and never fires. Then every now and then it'll crank and crank for maybe 10-15 sec and finally fire. The fuel pump runs when the key is turned.
It's really random, too. Sometimes it'll sit for several days then not start. Then it'll sit a few more days and suddenly start. Sometimes it'll sit for only 30 minutes and then not start. I haven't noticed any relationship to weather, as I thought maybe I was having problems due to condensation/rain. Could it be my computer? Should I swap out my chips for my stock chips? I'm really lost here as this happens 50% of the time.
I also know it's not a problem with engine speed because hooking up another battery to see if I have enough cranking amps doesn't change the situation. The ref and speed sensors are new as of last fall. I gotta get this thing on the road as it needs to drive 1600 miles to AZ next week :/ Any ideas?
Ok I just got her started by pulling out the DME and KLR boxes. I held the key in the start position and tapped on the boxes and she fired. I don't know if I just got lucky and she started or if the knocking on the computer boxes (I knocked on both the DME and KLR boxes, though I think it was on the DME that it fired up) did the trick. If this is the problem, what is my remedy?
Haven't opened them up yet. I'll be able to get to that tomorrow when I have light to work with, but as of now, it's sitting in a parking lot with no available light.
When I first started having these starting problems, I searched the boards, and someone had gotten theirs to work by pounding on the floorboard. It may be corrosion, possibly caused by a leak from the battery tray. I'll find out more when it's light again.
Wow another old thread (2006!) Kudos to FRZ for clearly utilizing the "search" function though! ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I'll add to this thread as a "something to check" for the next person who uses the search function...
My car at one point developed the random "no-start" issue. My reference sensors crumbled when I removed them (like old cheese, literally, the connectors crumbled.) So I replaced them with brand new ones from Pelican. And on random occasion, I'd STILL get a no-start.
The whole "jiggle the wires" trick always did it. Even with the brand new sensors.
My theory (just a theory)... the signal that comes over these wires is pretty weak. The two wires, when routed right next to each other, can sometimes cause interference with each other and cause the car to not start. By simply moving the wires around a little, you eliminate the interference.
I haven't had a no-start issue since I made sure to route the two reference sensor wires separately and keep them away from one another.
