WTB: Banjo bolt crush washers for Tial 38.
Hi,
I'm looking for 2 crush washers only. Search on the web but they all want to sell them with the banjo bolts as kits. Call me cheap but don't feel like paying $20 for only 2 washer. Thanks
I need one, as well. I'll probably end up picking one up from McMaster (just an aluminum washer with the correct dimensions). Let me know if you find a better source.
I just got the whole banjo kit from Forced Performance in Texas. You could call and see if they'll sell just the washers.
http://forcedperformance.net/
However, they are just aluminum washers, nothing special about them. On the top port all that matters is the inner diameter, although on the side port I think the outer diameter might make a difference as well. If you have two that are the right size, sand them down a bit, and use them on the side port. Then go to a good hardware store and find either aluminum or copper washers with the right inner diameter for the top port, and you are set. I can't imagine they will cost more than 25¢.
