speed sensor wire and insturment plugs
Does anyone know which wire is a direct feed from the speed impulse sensor to the speedometer? It looks like it is terminal 14 on plug B and is a Blue with a Red stripe .5 wire. I however do not know if it is for sure plug B or if this is the correct wire (Directly from the hall sensor output).
Also is there a way to ID which plug is A, B or C? the marker is worn off of 2 of my plugs.
Sean
Sean
