Stock turbo downpipe question
On the stock downpipe, there is a 3-hole flange at the end that the cat/test pipe bolts to. Mine has two bolt holes and one stud. Is that the stock configuration -- or did they originally come with morel studs?
Either way, it's a normal screw-in stud, right -- not welded or otherwise fixed in place?
Defending the Border
Rest In Peace
Rest In Peace
Tom, pretty sure three studs, regular screw in's. If the flange wasn't cast, seems like a good idea to tack weld the stud to the flange, this is one spot where studs work best.
