3.0 crank in a 2.5 block
2.8 liter displacement and some grinding on the block depending on which rods you go with. The 2.8 upgrade requires at a minimum new pistons if you can find custom made pistons to work with the 3.0 rods or better yet new rods and pistons.
3L crank (88mm) + 100mm bore = 2.8l (actually a bit less). It's called a 2.8L stroker.
To get there you need:
- 2.8L pistons to use with stock length rods. ANDIAL sold them, not sure if anyone else does.. or if they do if it's any good.
- Stock rods require some work to clear the case. Aftermarket rods will clear fine.
- Using the stock 951 pistons with a shorter rod is not a good idea. The geometry of crank/rod becomes undesirable.
Of course the tuning... It might be less expensive to do a 104mm 2.7L (Chris White) or buy my 2.8L 106mm bore.
Originally Posted by Rogue_Ant
I thought 3.0 rods are the same as 951 rods....?
Rogue
Rogue
If you have a 3L crank and you need to sleeve the block, then 3L is about the same cost... If you do go to 2.8L or 3L, we need to upgrade your software to handle the longer stroke.
Small Business Partner
Originally Posted by fast951
Same length.. Stock rods require some work to clear. Aftermarket rods (stock length) will clear...
Thanks! Good info to know.
Rogue
I'm planning a rebuild to make a 2.8L stroker. I already have aftermarket rods and my head is in great shape. The guys at Lindsey Racing tell me all I need is a 3 liter crank and different pistons.
What's a lightened knife edged cross drilled 2.5 crank worth?
Want to trade cranks?
How about some 15K mile coated stock pistons?
I just parted out a S2 short block, and the oil pan is sitting in my garage. I noticed that the scrapers for the crank are different than those in my 951 pan. They look to provide more clearance for the rods. Is this something that you guys account for, when building a 2.8, or is it not necessary?
-Jon
-Jon
Originally Posted by hot-J
Yeah I know.... This is basicly my problem........ I have a 2.7 head stock, 3.0 crank stock, and a blown 2.5 engine...... What to do.... what to do....
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
The 3.0 turbo engine requires some custom piston configuration to get the right compression ratio and wrist pin clearance – but thats included in the MID sleeving kit.
So if you sell the 2.7 head you can have the parts to build the 3.0 for a net cost of $1750 (plus shipping !)
Maybe its me…but that seems like a no brainer!!!
