Whats The Part # for a 2.7 head?
Originally Posted by JET951
is there any other benifit of the 2.7 head
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
The main reason that the 2.7 heads are used is that they are a direct bolt on to the 3.0 blocks and are also the same configuration (intake and exhaust) as the 2.5 heads. This is the ‘easy’ way to bolt on a turbo to a 3.0 block to gain more displacement.
It used to be just about the only way, now there are other ways to get the extra displacement.
The intake valves and ports are bigger on the 2.7 head than the 2.5 head – but you wouldn’t want to mod the head or block to bolt on a 2/7 head to a 2.5 block – that would be going backwards!!
Chris White
Chris White
So even though you might sleeve a 2.5 block up to a larger capacity there would be no real gains to be had by using a 2.7 head?
The 2.7L flows much better than the 2.5L head, so there is a performance advantage. However, to bolt the 2.7L head on a 2.5L based block, you have to modify the water jacket at the front of the head.
It might be easier to get a hi-flow 2.5L head.
Originally Posted by Rich Sandor
Doesn't the 968 turbo use a 2.7L head? Does the 968 intake mate to the 2.7L head?
The 968T did not use the 968 NA head..
Konstantin knows all about the 968T, I'm sure he'll join us if he's online.
