Rear quarter windows.??
Hi folks
im looking at replacing the rear black [ alloy ] trims that fit round the rear quarter windows. Mine are getting a bit corroded...
Does anybody know how easy i is to remove + refit them.??
I realise that i might need to remove the rear windows , but ill probably combine that with fitting better rear speakers , as i belive these arent accessable with the window insitu....
Anybody got a removal/ refit guide.?????
Moook,
You will need to take the windows out to replace the metal trims, you cannot put them in whilst the window is in situ.
Take window out and remove old trim ( you could repaint the old ones as I did? ). press your new trim into the groove in the window rubber so its nice and snug, have a friend help when you go to refit. First get some washing up liquid soap and smear around the window opening to aid in refitting. Get some cord long enough to fit in the channel of the rubber, get inside car and have friend hold window up to the opening, you now will start to pull the cordtowards you inside the car, this will pull the rubber over the metal lip and make a nice seal as you keep pulling the cord all the way around the opening, your friend will be pushing against the glass as you go.....its real easy really, just take your time and it'll work for you.
Originally Posted by Moook
Thanks.
It sounds a pretty easy job....
How do you remove the window without breaking it.??
Moook:
Click Here for an excellent write up (with pictures) on Paragon's Tech Site showing how to remove and re-install the rear windows.
Only thing I might add to this is that I had good luck using a wide, plastic scraper to help position the rubber seals on reinstallation. The width and the softness of the plastic kept me from damaging the seals.
HTH
HTH
My pleasure, glad I could help.
I did this by myself and the first time around was a little scary. It'd be much easier if you had someone on the oustide of the car to catch the glass when it comes out. After 20 years the rubber had gotten fairly 'attached' to the frame. I used the scraper to pry (pryze, is that the proper British term?) it away from the frame and then was able to push it out without too much trouble.
