Dyno question
Where are the spark coming from? I would guess, yes you have a crack.
They were in the area of where the crossover to wg connection is. This is also the area that was glowing red hot. The other reason is that I am missing a good 30 to 40 hp compared to similar setups. And increasing boost doesn't change much.
I'll send you the dyno sheets when I get them John. Chip was good once I turned the fqs back to 0, where I thought I had it before I started.
I will. I'm going to pull the car down for the winter in the next week or so and the top end of the motor will be pulled. I've also got plans to inspect and coat all of the exhaust.
Kevin, Questions regarding your chip should be taken off line.. Each chip has a unique FQS settings, posting the values for one on the list will cause all sort of confusions.
You should not be running with FQS pulling timing, not unless you are using terrible fuel.
Ok, I wasn't. I was just trying to figure out what the percentage it was and why I would use it, but you just answered that. No biggie though as it's not needed. I was running some nice 114 last night, but didn't get to play much as we discovered the crossover issue.
