Loose Cold side turbo?????
Drive-by provocation guy
SHOULD THE FRONT SIDE/COLD SIDE OF MY TURBO BE LOOSE?????
I am thinking NOT. But before I blast the company that sold me this turbo (as a replacement for their ruebuilt turbo that blew to ****)
Anyone???
As I was checking the turbo to IC hose, I tugged and noticed the turbo was moving back and forth on the front/clode side.
Fixable??
If so, is this a turbo I should keep???
Anyone???
Fixable??
OK, but this has been installed for over a year now.
Also, is there a way to get at the bolts to tighten without having to pull the turbo???
Tightening the bolts should be doable, but if it has been run like that, the compressor fins may have hit the compressor housing, depending on how loose the housing is. I'd pull it for inspection.
Well, I just developed a boost leak and was checking things and did not see any leaks after pressurising and started to check the turbo to IC hose and noticed the cold side was slightly loose.
I make about 8-10psi but will NOT touch boost unitl I get this tightened up.
Would this have been a sudden come loose thing or slowly over time?? I am thinking slowly since spool up and max boost all seems the same.
Todd dont worry man, most turbo builders will ship there turbos with the housing(s) loose for clocking the to each set up. Most people dont post about this because most of the time is pertty obvious or and the biulder tells you it is loose. ether way that is not samething to complain about in my opinion.
Regards,
AL
Regards,
AL
OK, so that explains why I have never seen this problem posted before.
Still not sure how it was secure when installed and just now looks like one bolt has come out a year later.
I can see it, just can't get at it. Hopefully can be done with only pulling the intake and not pulling the turbo itself.
This has nothing to do with the quality of the turbo. It is all because of the poor installation of the turbo. When the turbo was installed and indexed it was not tightened down enough. If you want to b!tch some one out it should be the person who put it in the car.
Also, you can call Alex Job (Alex Job racing???) and he has their phone number also as he was the owner's partner in racing 911 and 951 and has them do some work on his track cars.
The place I got this replacement turbo from tried to say the same about the rebuilt turbo they sent me that fried in about 1 week since the "rebuild" of the turbo was not done properly.
The installer should have tighnen the housiBut like i said before it is nothing to complain about. Maybe it was a honest mistake. Belive it or not even race shop make mistake. Thing it that it looks like nothing bad happen and that is what matters.
Regards,
AL
Regards,
AL
Defending the Border
Rest In Peace
Rest In Peace
Check your IC tubes for pieces of housing material and inspect the compressor wheel for "blade tip curl", that will tell you if the blades came in contact with the housing.
Regards,
AL
Regards,
AL
Yes, you are 100% correct.
TMS951: Didn't mean to lash out to you I just kept being told with the rebuilt turbo and then this one it has to be the instalation and the shop I go to are top of the line, Porsche only shop/race shop.
But that doesn't mean small mistakes can escape anyone.
I would have suspected though if it was not installed/indexed properly by them, this would have come up a long time ago and not a year or more down the road from instalation.
