MBC not working???
10-29-2006 | 07:50 PM
MBC not working???
I turn it down all the way I still got boost! Tial WG side port to inlet of MBC and a T to the IC pipe, out port of MBC to top of tial... am I missing something?
10-29-2006 | 07:57 PM
you should still have some depending on what your wastegate spring is which is the minimun you can run
10-29-2006 | 08:12 PM
I am starting to think i have my Tial installed backwards. The bottom of the WG goes to the smaller 90 degree pipe that goes into the crossover, and the side goes to the bigger pipe that ties back into the exaust right?
10-29-2006 | 08:16 PM
thats how I have mine maybe your lines are messed up? How much boost are you running even with the mbc turned down? Do you recall what spring your tial has?
10-29-2006 | 08:19 PM
I turned the MBC all the way clockwise and still saw 12PSI in 1st gear.... it has the 14lb spring..... maybe this is why....
10-29-2006 | 08:22 PM
Jason - you will NEVER be below 14psi then.
Also - what kind of mbc do you have?
Clockwise on a standard black **** INCREASES boost.
10-29-2006 | 08:25 PM
Quote:
Also - what kindofmbc do youhave?
Clockwise on a standarb black **** INCREASES BOOST.
This is one of those times I wish I gave it more thought before posting.
10-29-2006 | 08:26 PM
Oh, and its a lindsey unit, and the directions say clockwise is a minimum......
10-29-2006 | 08:28 PM
Quote:
If I turn my Lindsey all the way clokwise, I will be at almost 50 psi.....
10-29-2006 | 08:32 PM
dont scare me.... tell me your kidding!
10-29-2006 | 08:34 PM
no,........
and YOU will be over 40.....
10-29-2006 | 08:38 PM
So are my instructions wrong? Or do you have a diffrent version?
10-29-2006 | 08:44 PM
Probably incorrect instructions. Even a standard 0-100 air compressor regulator is the same - clockwise to increase- they are all the same.
10-29-2006 | 08:47 PM
That **** makes me angry....... What if I did damage to my engine......
10-29-2006 | 08:53 PM
Do you have an aftermarket boost guage?
