How do I test ABS sensors?
Hi,
My ABS warning light is on. The obvious place to start is with the sensors. Is there a procedure for testing them to determine the FUBAR candidate?
TIA
Lanny
TIA
Lanny
Further to the above: I recently changed engines in my car and had the master cylinder out. Do I need to bleed the ABS system and, if so, how and where do you do it. The ABS warning light has been on since I swapped engines but was never on before. Also, I changed out all four calipers. C'mon guys...a little brain trust here and help a man out????
TIA,
Lanny
TIA,
Lanny
I've went thru this before. does the light come on as soon as your start the motor or after you start moving above 2mph, in the latter case use the below procedure.
https://rennlist.com/forums/924-931-944-951-968-forum/272248-abs-problem-resolved.html
Good luck
Good luck
Thanks, Sysgen. The problem occurs after the car is moving slowly so it is a sensor. I really appreciate your input and help!!!
Lanny
Lanny
