044 fuel leak
044 fuel leak
Well, when I put the pump in I had the wires mixed up, and the pump was pumping backwards....... now I got it straight, and there is still alittle fuel comming out the back where the fitting connects to the tank. Its the fitting that screws into the pump.... should I have used teflon tape there because I didnt?
Yup thats my problem! Maybe I was sleep walking or something when I put this togeather..... Now I have a coolant leak hiding from me....... Then I should be up and running! Thanks guys!
