Alternator or Voltage regulator?
I put a rebuilt alternator from Paragon on and it is charging, but I think it might be a good idea to get a new battery, since I've drained it a few too many times, I've had the car for 3 years with the same battery and who knows hold old it is. At idle, with lights, radio, interior blower on, it is charging at about 13.5V. Is this ok? The old alternator was helaciously hard to spin over, I assume the wires and bearings were trash.
Originally Posted by SchnellerUmsetzer
I second that but is likely that there is a ground out some where too. Do not jump the car or charge the battery with with it hooked up to battery cables. You can fry the DME and KLR!
several shops + the po who is a shop mech at the hi $$$ shop here said "no problem" charging with cables connected and i've been doing it for 3 years as needed.
87951
