If your injectors dont flow enough..
The Impaler
lets say you had the vitesse stage 2 kit kit or something like it, and you dont upgrade your injectors, the result wouldn't be catastrophic am I right? you would just flatten out your maximum power when the injectors reach the height of their duty cycle, or is there something I am missing.
Some ECU's will cut ignition once the MAF hits a certain voltage. This is why HKS makes the fuel cut defenser (FCD) for some cars.
If you were to run too much boost on small injectors you'd get alot of detonation, in fact if you didn't let off it probably wouldn't take but a few runs like that to destroy a piston / headgasket / valve / etc.
Always try to have more injector than you have turbo. If the turbo pushes 400whp at peak output then opt for 72 lb. injectors. If it pushes 500whp then you can go with even larger. At the point you have 72 lb. injectors your partial throttle duty cycles are in the dumpster already, might as well just get something big enough to save the engine in case a wastegate line pops off.
I say spend the extra amount and buy larger injectors. It's just not worth it considering how cheap injectors are and how much damage can be caused. The stock injectors are about maxed out at ~300rwhp. I have seen some pushing more hp with this on stock injectors by using higher fuel pressure, however that's not the best idea.
Cast Iron Man
Bigger injectors increase your margin for safety. A MAF setup could easily out 'breath' a stock injector's capacity to supply fuel. It's even been suggested to me to go with bigger than stock injectors on a 26/8 with AFM and chips.
The Impaler
My injectors seem fine on my k-26/8 with vitesse software, but yes if I were to make any real changes it would only make sense to upgrade my injectors, I was just wondering thats all...
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Originally Posted by Driftomagnifico
At the point you have 72 lb. injectors your partial throttle duty cycles are in the dumpster already, .
Mike S & Tconn, you are both correct. The FQS settings differ between chips, each chip receives a document describing the FQS settings.
Ryan, the software must be matched to your injectors. The injectors must exceed the power capability of your turbo.
