Holy WTF?????????
Originally Posted by Zero10
They have license testing in Alberta?.... You're kidding, right?
I thought they all came in boxes of Cracker Jacks? (speaking as a true Calgarian.....)
Seriously though, euro cars did not come with O2 sensors and do not require them to run. This is part of how they claim higher power output from the european cars as well. Would a WBO2 fit into the threaded hole for a normal O2 sensor?.... If so then this is a most convenient thing for you.
There was a recent scandal because one of our middle Eastern brethren who owned a licensing / registry was passing truck licenses out like free passes to the circus. I honestly cannot believe what the licensing people pass and turn loose on our streets. I don't know whether the WBO2 will fit or not but time will tell.
No need to put in the O2 sensor unless you put in a cat. The only reason for the O2 sensor is to ditter the AFR ratio so that the cat can reduce then oxide the exhaust gas. One more thing, you will need to tell the DME that you have a O2 sensor by changing the resistor value in the country plug. If memory serves me correctly, the resistor is removed for O2 configurations.
Originally Posted by lart951
This is not a joke or either sarcams, sometime ago someone told me that Canadians are the only people in the world that **** on their own drinking water is this true, iam not joking or trying to be a troll it's a honest question.
TIA
Lart
TIA
Lart
Originally Posted by Lanny Curlett
Hi Lart,
We have chatted through E Bay. My trading name is Frozenass. Good to see you back on the board! I'm not sure what you mean with the pissing question but we drink the same water as everyone else. I guess if you are downsteam from another town there me be some effluvia in the water but that is true for every city and town in both our countries.
Lanny
Lanny
Lart
Actually.....I wouldn't drink tap water in Toronto. Their water comes from Lake Ontario....you're bound to glow in the dark if you drink too much of the stuff!
The water that Lanny and myself get is from the Bow River...which comes directly from the mountains. It is supposed to be one of the best quality of water you can get in the world...
(BTW....Prez Bush Sr. says that the best flyfishing he ever experienced was on the Bow River in Calgary...)
Geesh....tough crowd here... .....I think I'll go back to the 964 forum....
Go to your Rennlist control panel....
https://rennlist.com/forums/usercp.php
And on the left side there is a column that says "edit avatar".... click on that, and you should be able to upload a picture. (assuming you have one on your 'puter)
Hope this helps!
Hope this helps!
