car wont start
car wont start
i just got my car all back together and it wont start. i know i have oil pressure...and i have fuel cause i can hear the pump...i dont think i have spark... i dont know if this matters but my tech is not bouncing when the starter is cranking...ST wanna come up to bristol...?? lol
If your tach isn't moving, then your ref. sensors are not giving a signal to your DME. Try fiddeling around with the connectors and tap on the sensors with a screw driver or something.
They are the two things screwed into the bell housing at the back of the engine. The connectors for them should be on a bracket at the back of the intake manifold.
Another option is the DME end of the connectors are loose, but that's less likely. Check the connector to the DME under the passenger side floor boards to test that.
