Don't laugh my dash caught on fire, need advice - Pictures Up!
#32
Gstreev,
I've got an '89 951 that I'm thinking about parting. If you're interested, I'll remove the complete harness and fuse panel for you. It's really not that bad removing it once the dash is out. All the wiring in the back is a bit of a pain, but not that bad.
Like Dan said, contact Rob Budd and have him recover a late dash for you. He's doing an airbag dash for me and does very nice work.
Good luck with your insurance company and sorry to hear about your sh!!ty situation.
Vic
Vic
#33
Thanks everyone for the offers to help, insurance adjuster is coming Friday morning.
He pretty much said they will total it. Then I have to decide.
Keep or not, depending on the buyback.
Repair to original
Part it
Barely streetable track car
Find one that needs a motor or bolt on body parts.
Repair to original
Part it
#34
Temprarily Banned per IB
That is just horrible, it pains me to look at it. I can only imagine how you feel.
As someone else stated, talk to the insurance people before you do anything and then go from there.
Regards,
Russell
Regards,
Russell
#36
If it was an S or 89 with 93K in good shape you will NOT be able to replace it for $4500. More like $12,000. I paid $12,000 for my 89. The paint had a lot of chips, but the motor makes 400rwhp
#37
get $4,500 for it?
#38
Well I live in NJ and I don't think I would pay much more they 3000 for it. Granted I havent seen it, and it looks like a great car, but figure it will probably cost about 2000 or so to get it back to a normal looking state. Then you have the issue of all the possible fried electronics and such?
Just my opinion, I really have no clue. If you add up the engine, wheels, body, etc. as a parts car what do you think that would be worth, maybe the 4500 or so, but the trouble to actually do all that, thats where I came up with the 3g. Also at this point, you sort of need to sell it to someone with knowledge of the genre, and not just any random sucker, so that will cut into your bottom line also. That being said, I do have a 944 in the driveway that needs a clutch, do I smell a total conversion, lol.
Either way, glad youre alive and goodluck with it. It will ride again.
#39
It would cost a lot more than that--- a new wiring harness alone would be tough to find and $$-- then of course the labor involved in installing it. . .
I sent you a PM-- I am interested-- hopefully we can work something out.
-t
#40
Basic Sponsor
$ 4500.00 that's too much money that car is worthless just sell it to a rennlister for $ 3000.00 or less
#43
The harnesses don't usually fry so there should be a lot of good used harnesses out there. Once the dash is out it would be time consuming but not too bad to replace the burnt with new. Some bits will run through doors pillars etc. but may not be damaged so you can either use the old wire to pull through or join (solder and heat shrink the splices). I guess headlining is toast and will need replacing.
If it was mine I would get it back from insurance at the best rate I could remove the dash and other damaged parts then go either the track minimalist route or the rebuild.
Good luck, hope it works out Ok,
Tony
Tony
#45
Originally Posted by reno808
I live about 45 min away from LI i can help you out. I already replaced 2 dashes. its really easy just time consuming.
I will be glad to pay you for your time. I will continue removing stuff
from the interior. Some of the connectors are melted, I will have to cut them to get them off, I will label anything I cut.
