How much power with these mods?
I am thinking of buying another 951 with the following mods, and was wondering what kind of HP the car should have as the guy has no Dyno sheet.
Lindsey Racing fuel Rail
SS braided lines
Areo Quip fittings
85 LB injectors
“044” Bosch high flow fuel pump
T04B turbo #8 hotside
Vitesse MAF
Vitesse Chipboard
AEM wideband UEGO
Auto Meter 30 PSI boost gauge
Manual boost controller
Lindsey Racing 4” exaust
Borla XR71 race muffler
3” downpipe
Heat Wrapped Headers
Full Exaust thermal coated
Watstegate dump
Tial 46mm wastegate
SFR intercooler pipes
HKS super sequential BOV
SFR front mount intercooler
Ported and polished cylinder head
Widefire head gasket
968 M030 sway bars
Racers Edge solid swaybar mounts and bushings front and rear
KLA Spherical droplinks
KLA swaybar braces
Bilstein escort cup coil overs T-bar delete 450/550 lb springs-street valving
Racers Edge camber plates
Turbo S transmission
Turbo S “big blacks” painted Yellow
Turbo S hubs
SS brake lines
SS braided lines
Areo Quip fittings
85 LB injectors
Vitesse MAF
Vitesse Chipboard
AEM wideband UEGO
3” downpipe
Watstegate dump
Tial 46mm wastegate
968 M030 sway bars
KLA swaybar braces
Turbo S hubs
SS brake lines
SS braided lines
Areo Quip fittings
85 LB injectors
Vitesse MAF
Vitesse Chipboard
AEM wideband UEGO
3” downpipe
Watstegate dump
Tial 46mm wastegate
968 M030 sway bars
KLA swaybar braces
Turbo S hubs
SS brake lines
SS braided lines
Areo Quip fittings
85 LB injectors
Vitesse MAF
Vitesse Chipboard
AEM wideband UEGO
3” downpipe
Watstegate dump
Tial 46mm wastegate
968 M030 sway bars
KLA swaybar braces
Turbo S hubs
SS brake lines
Half of the list makes no HP and the other half or so might put you in the 3-350 range. depends on boost levels and what the turbo really is.
You need more info.. although big black painted yellow is worth at least 10 rwhp, lol..
looks like a great parts list.
Basic Sponsor
Basic Sponsor
Hey!! you got any PS brackets and tensioners??
Basic Sponsor
I found it here
Unaffiliated
That parts list sounds a lot like what I've got, but I'm not sure about your To4b vs my super65. I did 390 WHP at 22lbs and some xylene in the gas. IIRC I had about 340 at 19Lbs. It all depends where you set the ****.
Originally Posted by lart951
10hp???? where do you get your figures, painted yellow is at least 25rwhp.
Hot-J, that sounds like a pretty nice car, judging by the parts list.
Originally Posted by Olli Snellman
Yellow "Big blacks" make 951 real fast. Check out my friend's Tommys setup. I prefer yellow GT2/GT3 setup....
