Question about Clutch Replacement.
Ok well I ordered a new turbo downpipe and 4 inch exhaust from lindsey racing. i have what looks like an oil leak from the rear main seal. I currently have the console area by shifter/intake manifold/downpipe/Cross-Over Pipe/exhaust system off. How much more work is it to pull the tranny/clutch to get to that seal. Also the flywheel looks like there is no oil on it/??? is this normal if the rear seal is leaking??
P.S. It took me about 10-15 hours to do everything that I have done up to this point only cause its my 1st time ever working on a porsche and some of those bolts were a pain
ohh and you can take the downpipe off w/o taking the turbo off. Just trim the bottom stud a lil bit and everything will slip off. This saved me a ton of time
Might as well do it now. Several PITAs of the exhaust and such are done. RMS leaks dribble down onto the crossover, which then burns the oil off. That gets mighty annoying after a while.
Do a few searches on the forum, theres threads with various tips for dropping the transaxle.
Total clutch time on a turbo is somewhere between 12-16 hours for a mechanic depending upon experience and which crossover tube you have. If the exhaust is pulled, you'll need to pull the tranny, slide the torque tube back, pull the clutch and have at it. It's not a hard job, but it is time consuming.
Basic Sponsor
Originally Posted by BlacknRedGT
Anyone know of a porsche guy in San Antonio who would be willing to help me out for some money??? Im not sure if I can handle the tranny myself.
You need to disconnect the tranny coupler 2 bolts
Remove 4 bolts from the torque tube to the tranny
Remove the odometer connection
Remove axles
Loosen bolt that attaches shifter shaft to to tranny linkage
Also disconnect the shaft from the shifter lever and move the shaft forward.
place a jack under the tranny
Remove the bolts that attach the tranny to the tranny mount
Lower the jack
You should be able to do it in one hour and a half without any previous experience.
Originally Posted by lart951
Tranny is not that difficult i can get the tranny off in 30 minutes or so.
Remove axles
Lower the jack
Remove axles
Lower the jack
ok I will try and see what I can do today..... still wondering about the oil on the flywheel question though?
Originally Posted by special tool
Be VERY sure it is not leaking at the oil pan gasket up in the raised section if there is no oil on the flywheel.
ok another question, since people actually respond in this forum How hard is it to change out the oil pan gasket??? Looks like you have to remove the crossmember?? Doesnt look fun
Hey Man
Originally Posted by RolexNJ
I don't know If I'd trust a guy like you with your expertise. I mean after all, dont you look like you jumped out of an MTV video shoot for a re-union of the Village People from the 1970s?
Little People are so Cool...bet he could drop the trans in less than 30 minutes, wouldn't even need to jack the car.
Basic Sponsor
Calling bull**** on the 1/2 hour, compadre....
Basic Sponsor
Damn, you stop harrasing ST, he is not talking to me because of you. Why don't you post the funny picture of brendanc that I gave you.
