Instrument cluster swap
09-22-2006 | 02:29 PM
I have a 86 951, will a instrument cluster from a 1988 work.
If anyone have a instrument cluster for a 86 modell ( in km/h), I want too buy one.
09-22-2006 | 02:33 PM
It should as long as the speedo are the same.
But I will let someone who has done it chime in.
09-22-2006 | 02:51 PM
It is the same size, but there is some small different in the eletric wiring diagram.
09-22-2006 | 02:52 PM
Yes - you can use any up to and including the 968..
09-22-2006 | 05:06 PM
09-29-2006 | 07:12 PM
Are you sure the speedometer from the 968 will work on a 944. Dosnt the 968 take the signal from the ABS.
09-29-2006 | 09:31 PM
Quote:
If I tell you can use it, you can bet your life on it.
09-30-2006 | 01:04 AM
Hmmm, I have a 968 cluster I just put in my 87 951, Speedo does not work. Not saying it is the cluster's fault, but it is strange
Cheers
09-30-2006 | 08:01 AM
Quote:
Cheers
You have another problem.
Probably sender contact or nylon gear.
The DME interprets from both drive types and outputs the same signal.
There are a couple videos on the web of my Euro 968 cluster in operation in my car.
