OOOOPs!
I am halfway through the reinstalling of all the parts from a belt/ seal/ pump/ rollers change and I realized that I replaced the sleeves and seal on the balance shafts but not the mylar washers, will this affect it, or can i keep going
I have forgotten them before, and it will produce a slow leak at high engine speeds. Oil wont dump out but it is definately worth going back to fix, you can reuse all the old seals without a problem if you are careful when removing.
Clarks Garage is your friend!
Regards,
Regards,
