How to make a boost controller
I will be getting an electronic bc soon, but i have the intake off doing misc work and want to go ahead and remove the cycling valve, so i will need a quick CHEAP substitute. How can i make one using home depot stuff?
http://www.hondatuningmagazine.com/t.../photo_11.html
Cambell Hausfield pressure regulator.
http://www.c-speedracing.com/howto/mbc/mbc.php
Using some pipe fittings, a spring, and a ball bearing.
The regulator is probably the ""better"" way to use that term loosely
Small Business Partner
Ball and spring is the better setup.... Most aftermarket MBC are this style. They don't let any signal get to the wastegate prematurely.
Rogue
Rogue
Campeck Rulez
since no one has said anything i geuss i will.
more boost needs more gas and or retarded timing. not sure how they do it with the 951 but you cant just turn the boost up without a chip or increased fuel pressure or something. so yes...its dangerous.
