Car goes full rich at WOT
Rocket Scientist
Just today while driving (slightly colder then normal) when I put my 951 to WOT it went off the charts rich (below 10.0:1) at about 3500 rpms. It never did this before today. It would run about 11.5:1 or so. Now it is really rich and I didn't do anything, lol. What sort of temp sensor could do this? I have a Vitesse MAF with sensor but that is fairly new. Temp sensor on the head possibly?
Rocket Scientist
I have had a small intake leak I have not been able to trace down but that was before. I still have the same vac at idle as I did before. Nothing has changed there.
The IAT sensor in the head would not cause this. A Vacuum leak, a damaged FPR, a bad engine temp sensor (of course check the TPS and the plugs). Something changed, you just need to know what.
Temprarily Banned per IB
Regards,
Russell
Rocket Scientist
Today I had some new problems. When I would be in gear at any given rpm and let off the throttle to decelerate....the car would push forward then let off without me touching the throttle plate. I could sit back and watch the wideband go to 13:1 then back to off the chart lean (which it should be off the chart lean with throttle plate closed on decel).
My idle hunts also, going rich then back to lean. I swapped the TPS out earlier this month so I think it is possibly the stock 02 sensor. I will try somethings out tonight. Thanks.
