A/F under boost
Would like to hear your comments. Below are the numbers under full boost
A/F
3500 rpm 11.7
4000 rpm 12.1
4500 rpm 11.9
5000rpm 12.2
5500 rpm 11.9
6000 rpm 12.3
And there is a spike too 12.4 at 4800rpm.
How does this look to all the experts out there? Possibly a little lean? What would be ideal, 11.8 all the way under boost? Should I leave it like it is or try and tune it a little better. The car put down 341rwhp on this dyno pull.
A/F
3500 rpm 11.7
4000 rpm 12.1
4500 rpm 11.9
5000rpm 12.2
5500 rpm 11.9
6000 rpm 12.3
Temprarily Banned per IB
I like to see 11.5 to no more than 12.1 across the board, if it's leaner on the bottom end under little boost it's no biggie, it'll usually run better. But it is also dependent upon what boost level you are running. If you're putting down 341rwhp then you're running 18psi or better, or you have an enourmous turbo. You've said nothing about your setup, which plays greatly on your A/F goal. But again, judging from the numbers provided and the fact that you're spiking lean at 4800-5000 you have at least a K27/8, maybe bigger. Late spool and slightly lean condition when it reaches full boost.
To answer whether it could be tuned better, a LOT of info must be provided, everything from your air filter to your exhaust tip. Then we would be better armed to give you a definitive answer of where you are.
Regards,
Russell
Regards,
Russell
Your AFR is fine, you can richen it up a bit to get 11.8:1 across. I'm sure you know that your chip/board is setup for pump gas as well as race gas. Make sure you never run the race gas maps on pump gas.
I believe the Stage 2 dyno on the website (Yellow color) is from your car (previous owner emailed it to me). Very nice power band, lots of torque early on (almost like a V8).
I'm new to the world of piggybacks and I don't know if I'm running race maps or pump gas maps. I'm running pump gas so I hope it's the latter! Is there a quick way to find out? John, I try and give you a call tomorrow.
did you buy that car out of Corpus Christi? The avatar looks like an engine that JAB Racing built, based on that intercooler pipe from the turbo...is that your engine?
Originally Posted by VRSTAGE2
Yes that is my car on your website. It is running great.
That's it. The intercooler pipes were done by a local guy in Corpus, it was painted in Corpus as well. The car came out of Dallas, where it sat for two years with a dead DME. Paul Piper bought it from the owner and brought it down to CC TX. He got with my partner in JAB Racing, Jim Lankford. I did the work up for the car with Jim about the budget, he did the engine as I couldn't get down for this build but would have loved to be there. It got new rod bearings, it has new OEM lifters that were sourced from a guy who'd been hoarding them. The head was sent to LR for a stage I refresh. There was no play in the crankshaft so the main bearings were not changed, nor did we think they were needed. The car has all new sensors(S&R, temp, DME temp, oil pressure sender) new water pump, belts, seals, gaskets, rod bearings, Cup Car PP and 930 disc for the clutch. VR II kit of course, new hoses and expansion tank. Rotors and pads were also done, along with the Mille Miglia wheels and I can't recall what tires or suspension. I think he was going to put 968 bars under it but can't be sure. The car fired on the first try. I think Paul also put in new carpet and and front seat leather. Paul brought it back to Jim about 3 months later after a couple of oil changes because there was oil in the intercooler pipes. The car had great compression, like 147-150 on all cylinders, less than 2% leakdown, Jim was baffled and called me. I asked him to pull the dipstick and low and behold, Paul had been adding 3/4 of an extra quart because he read on "RL" to add a bit extra. They drained a quart out, Paul drove the car for a month, all was great; no more oil in the pipes and it was on ebay the next month because he proposed to his girlfriend and they bought a house
! good find and a nice car, congrats. Get your membership here, it's well worth it.
That's it. The intercooler pipes were done by a local guy in Corpus, it was painted in Corpus as well. The car came out of Dallas, where it sat for two years with a dead DME. Paul Piper bought it from the owner and brought it down to CC TX. He got with my partner in JAB Racing, Jim Lankford. I did the work up for the car with Jim about the budget, he did the engine as I couldn't get down for this build. It got new rod bearings, it has new OEM lifters that were sourced from a guy we knew who'd been hoarding them. The head was sent to LR for a stage I refresh. There was no play in the crankshaft so the main bearings were not changed, nor did we think they were needed. The car has all new sensors(S&R, temp, DME temp, oil pressure sender) new water pump, belts, seals, gaskets, rod bearings, Cup Car PP and 930 disc for the clutch. VR II kit of course, new hoses and expansion tank. Rotors and pads were also done, along with the Mille Miglia wheels and I can't recall what tires or suspension. I think he was going to put 968 bars under it but can't be sure. The car fired on the first try. I think Paul also put in new carpet and and front seat leather. Paul brought it back to Jim about 3 months later after a couple of oil changes because there was oil in the intercooler pipes. The car had great compression, like 147-150 on all cylinders, less than 2% leakdown, Jim was baffled and called me. I asked him to pull the dipstick and low and behold, Paul had been adding 3/4 of an extra quart because he read on "RL" to add a bit extra. They drained a quart out, Paul drove the car for a month, all was great; no more oil in the pipes and it was on ebay the next month because he proposed to his girlfriend and they bought a house
No, no damage, it just scared the $hit out of Paul. I don't think so, it should have SFR 3" exhaust under there - Jim didn't say anything about getting a pipe like we have on the race car, which vents to the atmosphere so I don't think so, but the other PO could have.
