List of things to check for low boost?
Im trying to prepare my self to figure this out when i tear into it.
So the car has good vacuum, the turbo seems ok, the WG (tial) works fine, so much for checking the obvious.
What next?
I figure it either has to be one of those things that so simple you'd never bother to check, or the last/worse thing it could possibly be.
What next?
Cast Iron Man
Check your cat. Mine was plugged. Also check all vac lines. Here is a pretty good illustration. http://www.lindseyracing.com/Merchan...ry_Code=VACDIA
Temprarily Banned per IB
I just thought of something, have you checked the function of the TPS? If the switch that tell it to go to WOT is not working, then it's just going to try to calculate load/rpm and adjust fuel/timing accordingly. With the car off just open the throttle body all the way and see if you hear/feel a click. And even if there is a click you might want to check the switch with an ohm meter to make sure it's actually working. And of course that the plug isn't full of dirt.
Regards,
Russell
Regards,
Russell
Originally Posted by Nico
Does somebody know how to measure the WOT switch? And from wich contacts on the switch(1,2,3,4,5,6)?
Regards,
Russell
I have been fighting a similar problem for more than a year without success. My car peaks then falls back to 9/10psi. I can force the peak upwards by using restrictors etc, but it still falls back to 10psi. I run tock class so I can't change the boost control in anyway to bandaid the problem. I have tried everything, I have no cat, the wastegate is new and pressure tests perfectly, all exhast piping is open. I have changed and substituted all the control elements many times, ie DME, KLR, cycling valve, TPS, maf, knock sensor, temp sensors. I am out of ideas, its as though the car thinks there's knock but I can't understand why. The car runs fantastic its just off on power. Very, very frustrating. I have searched all the threads many times, and seen that others have had similar problems, but there never seems to be anyone fessing up to what they found, and what fixed the problem.
OK...
I seem to have this switch confused with the throttle position sensor (potentiometer), wich has 6 connectors.
Now where do I find this WOT switch? I can't find any comment about it in the Factory Workshop Manual???
OK...
For better reference to both check out clarks garage:
http://www.clarks-garage.com great stuff here...
Russell
