RS Style Door Panels
Doc, two thumbs up on the RS panels! I would have kept the top half stock, and just done the bottom 1/2, but it still looks good either way.
I also have the 968CS centre console.(minus the cup hold and anti-slip padding) Lightweight baby!
Originally Posted by chris951
Did you use the opening for the armrest top on the door panel to mount the pull strap?
Originally Posted by reno808
doc can you explaing the drilling part. srry i am kinda dumb
6mm shaft with a 10mm head bolt?
Yup, I used a 6x1.0x20 IIRC (10mm wrench). You want the shortest bolt you can use. I used a nylock locking nut as well. You could use a standard bolt as well, something 1/4"
Update:
Finished the interior. Replaced the shiftboot, put in the seats and harnesses, and deleted the rear seat and replaced with carpet. i think I am happy with the interior for now....until I have the dash recovered......
