Pin # on DME/KLR for Air Temp?
Small Business Partner
What is the pin # for the input signal to the DME/KLR for Air Temp?
Rogue
Rogue
Temprarily Banned per IB
From this diagram:
http://www.motronic944.com/latewiring.htm
it looks like pin #22
That's DME pin #22
That's DME pin #22
That makes sense, much more pertinent information for the DME than what the weather is. Reason I asked was that I'm in the process of installing the 968 outside temp display, which uses a sensor in the passenger mirror. If there was already one that I could tap into, that would simplify things.
If you look inside the AFM you'll see a little plasitc tip protruding into the air path, that's the sensor.
Originally Posted by gregeast
Just curious, is that measuring ambient air temp or intake air temp? Anyone know where the sensor is?
