Zeitronix Question
Zeitronix Question
I've finally found the time to hook up the Zietronix WB02. Which DME wire do I
connect the TPS input to?
The display is much bigger than I thought it would be. The only place I've found to put it is in the glove box. I was thinking of putting it above the rear view mirror but not sure how usefull it would be there.
Any ideas besides under the radio?
Rennlist Lifetime Member
Its actually KLR pin 22.
I had these made up for electronics mounting. The wood boxes were made by Rennlister Griemman, I mounted the electronics and did all of the wiring.
This is the wiring harness I made to get it all done. All of the connections to the factory harness are soldered in 12" leads which run to that milspec AMP connector. From there, the connections run to their respective device - Vitesse SMT6, Vitesse Wasted Spark, Zeitronix, Greddy Profec B, Greddy timer, and the IAFM 1 which I use for injector monitoring. Its covered in the Firebraid stuff lindsey sells. The two smaller metal Dsubs near the AMP connector are used for test ports. They run from the Speed and reference sensors to simple wireclamp type connectors. I used these to troubleshoot a flaky no-start with an oscilloscope and the dme plugged in.
And here is the zeitronix mounted:
I like the boxes. I might just remove my VDO boost/vac gauge and install
the display under the radio.
Tom , I remember reading your post but had forgotten who posted it.
