If you cut the metal crimp on the end attaching to the banjo bolt of, you are left with the metal insert that you can use any vacuum/etc hose on with a clamp on both ends.
Yes, cut off the crimp as they suggest, but use a high pressure hose in it's place. This is the signal to the wastegate/CV, you don't want to use anything cheap here.
