MAX HP USING AFM??
Temprarily Banned per IB
Originally Posted by Rogue_Ant
Exactly how does the DME provide fueling @ WOT then?
Rogue
Rogue
http://frwilk.com/944dme/afm.htm
Regards,
Russell
Once the AFM signal is maxed out you are relying on the WOT fuel map settings to determine your a/f ratio. Thats why aftermarket chips are designated for a specific boost level, they are setup for a specific flow.
Should add that you can get more fuel out of an AFM setup with a piggyback, as there is room above where the AFM signal maxes out. The highest AFM voltage readings i remember anyone posting is around 4.5v (i got 4.3 running a k26/8 at 16psi), so with the piggyback you can utilise the remaining 0.5v to dial in additional fuel.
Legend Killer
Originally Posted by PuttingThePoorBackInPorsche
If the barn door is fully open, producing "max flow" signal to the DME this could be a problem especially if the boost is jacked up. Think lean conditions.
[QUOTE=hally]Once the AFM signal is maxed out you are relying on the WOT fuel map settings to determine your a/f ratio. Thats why aftermarket chips are designated for a specific boost level, they are setup for a specific flow.
QUOTE]
Put another way, once the barn door is open all the way, the DME will supply a specific amount of fuel. All other things equal, that amount of fuel will remain the same even if you triple the boost, since the extra boost can't open the door any further. The DME just sees an open barn door in both cases.
QUOTE]
