CA Smog problems...
Originally Posted by Brantley
- Used a fuel additive product called Blue Sky from blueskycleanair.com. This product claims to lower NO and some other improvements.
Below is the link to all the ugly details,
http://www.bids4gigs.com/smogtestprogress.xls
That additive is simply a volatile solvent; using fuel injector cleaner works great too.
My buddy's 944 kept failing, so I told him to add a bunch of f/i cleaner (two bottles) when the gas tank is really empty. He passed no problem.
IF you fail at this point -- running hot, high rpms, f/i cleaner -- throw some methanol in there. No kidding (don't go higher than 40% methanol:gasoline). The car will run like **** but it will pass with flying colors!
Then, make sure to fill that tank up immeeeed to lower the concentration of the f/i cleaner and methanol.
Just a helpful hint.
Thanks forthe advice ausgeflippt951. I will keep this in mind for the next time! Luckily, I have 2 years before I have to deal with this again!!
just get some 100 octane fomr sonoco. make sure you drain your tank or drive it as empty as you can. Also make sure you drive around before you take it in. If the car is hot it seems to get much lower HC and NO. I bumped my octane to 104 with home brew and ended up getting lower score than my 2004 bmw.
No prob man. What do you mean, 2 years? I thought you lived in CA, home of the free, land of the air *****...
I can verify that methanol works. As stated go right to a gas station and fill up as soon as you pass. In fact maybe even bring some gas in a can with you. last ditch solution but it does work.
