Questions about K-26 tolerances - is this acceptable?
Set to Full-Auto
So I was provided the specs for the allowable play on the shaft:
.42mm sideplay
.16mm endplay
With my Mitutoyo digital indicator and some granite stands I was able to measure anywhere between .38 and .40mm of sideplay on a turbo with 100% dry bearings. The shaft spins freely and the blades look good, just a little dirt and dust from being stored. This car is not going to be modded and will be a daily driver for my dad. Would you be concerned about these readings?
.42mm sideplay
.16mm endplay
Set to Full-Auto
Ahhhhh, well then - measurements should be better - there is less play on that side. Thanks for the info, I will re-measure tomorrow and report back.
