What and where do these wires go?
I notices this connector was off today while I was troubleshooting stalling issues. Do I need to take the intake manifold off to reattach this connector?
Where does it go and what does it do?
Thanks...
Thanks...
cycling valve I believe.
EDIT: yup. added a pic. assuming you want it connected (if you don't have an MBC or EBC) you should be able to get it back on from the back side of the manifold.
EDIT2: this pic was before I did the venturi delete and cleaned up under the manifold. yuck.
I found your stalling problem! Your fuel line isn't connected!
I think Cra$h is right though. If your cycling valve is removed, then don't worry about it. If you've still got it, then you'll have boost issues, but it shouldn't cause your car to stall out.
Great. Thanks guys.
I deleted my cycling valve and totally forgot.
skene - That line was disconnected because I swapped FPRs to see if stalling was due to my 3 bar FPR being stuck.
