Fidanza part no. and more
Fidanza's light weight flywheel for turbo 944 is advertised on ebay and other suppliers as part no. 199441 weighing 6lbs.. question is, Fidanza's own application chart lists part no. 199301 weighing 13lbs as the correct 951 LWF and selling considerably more than the 199441 unit. Which is correct?
Regarding Lindsey's 2-pce crossover pipe, does it simplify the clutch change procedure at all? I have the early 87 one piece crossover and half the car is currently sitting on the work bench while I'm doing a clutch change.. hence the question.
Also, is it possible to remove and save the freon in the AC? The car is immobile and needs a new AC compressor.
Chris
Chris
