Race Gas
Av Gas 100LL is not appropriate for use in a car unless the car is tuned for it. Other than the lead damaging the O2 sensor, the density of the av gas is different than regular fuel (from memory, there is like a 12-15% difference).
Running 100LL will cause the car to run lean. When mixing it with pump gas, you might be ok.
Av gas is very stable, again, the car must be tuned for it.
