Tried some C16 today
Well I tried some C-16 today it costs about 9.00 a gallon or more , I have been running cam 2 110 leaded I can get it at a local pump an its 4.50 a gallon.I didnt notice any seat of the pants diff an I ran both fuels at 20 psi.The AFR stayed within 2 or 3 tenths of where the cam 2 was.I will go to the dyno I guess next week an compare.
Erik
Erik
i doubt you'd see a difference in power if you ran the same amount of boost with the same setup. both should have a high enough octane to prevent detonation at that level.
C-16 stoimetric is 12:1, not 14.7:1 like pump gas. So you were running way to lean with a high ehough octane that you did not blow up you engine because you ran such low boost for that gas.
I was running about 11.9:1 on the c-16 @ 20psi an 11.5:1 on the cam 2 110 leaded @20psi.
Drive-by provocation guy
Erik
Erik
The only way to see a difference with different gas/octane is if that fuel has a higher kilo calorie potential.
Erik
Erik
