Walbro fuel pump fittings?
I tried last night to put the pump on the stock fitting fit in mine but the pump was dead
so now I have a walbro gsl-392 that is a paperwieght and have to buy another
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
The pump is at walbro and they are testing it and most likely going to send me a new one. As far as fittings you need the 12mm barb and the stock banjo fitting fit but... I never tried using it since I had the new 12mm banjo from http://www.autoperformanceengineering.com/. I also found out the stock banjo has a check valve which holds the pressure in the fuel lines.
Originally Posted by por4ever
Here is the chart from the now defunct Dark Lightning page. I have the whole page saved if anyone wants it. Too bad this site is gone or did it move somewhere, anyone?
thedge@gmail.com
