Too many Head Gaskets!!!!!!
Originally Posted by toddk911
Because at crusing/idle the a/f is very lean.
"It turned out to be a little slit in the FPR vacuum hose which, for some reason, would only pop open occassionally."
Tom: can these be checked doing a pressure test or only visably checked?
I actually found it with a vacuum pump (MityVac) while testing the FPR on a hunch. It would hold vacuum or not depending on how I wiggled the hose.
