Change from #6 to #8?
Not to start anything without DFASTEST not chiming in first...but that K29(engine is built to take 24 psi...not sure what the turbo theoretically could max out at) he runs is usually at 1-1.1 bar day and night unless he is not sure of what the other guy is packing.
Originally Posted by ehall
DEFASTET has a custom k29 and does in fact run 21 psi EVERY DAY! He doesn't touch it at all if for no better reason than he doesn't want to put amateur hands on a specially built machine.
Originally Posted by DFASTEST951
ehall, Happy New Year Bud. I run 100 octane all the time as I can buy it at the pump out here. I just want to make sure if I ever want to turn it up, I'm ok. I didn't know 1 bar was only 14.5 psi. The highest I've ever had it was a Viper Venom 550 and a crazy Supra that I've spoken of before. Then I've had it up to 1.2 and the Supra 1.3. Took the Viper, and the Supra caught up to me at about 175mph.
Dilberto, I would love to do a high speed run on Bonneville. Thing is I'd have to change my fifth gear as I've already done it on the newly constructed beltway in Vegas. Top actualy speed in my car is 194mph with a newly calibrated 220 mph speedo from North Hollywood Speedo Shop. Audi's AWD Transfer case...That's a hell of an idea! I wonder if that could be done. That would cure our launch problems. Good idea man...
Andial I think you should go with the #8 if not a #10
I am not an advocate of a 27/8 on 2.5 street car (I had one on my car in late 90's when Powerhaus was pushing them) as it is laggy, and frankly there are better alternatives such as Vitesse now. However that being said, you may want to check with Clark as in Clark's Garage. He had a 27/8 on his 2.5 that he HATED, due to the lag. He built a 2.8 using the same Andial components you have, combined with some head work, namely larger intake valves from an 89 2.7 NA. (I forget who did that in late 90's) but anyone can do it now.
In any case his 27/8 came alive with that combo. No lag issues, and he was satisfied with the performance.
Now all that being said, as others have already pointed out, to convert your 27/6 to a 27/8 you will need a #8 turbine as well as the #8 hotside.
These parts are not cheap from KKK, so you are likely looking at picking up a 26/8 just to get the turbine and housing and then send to a rebuilder to for a complete rebuild/balance. If you can find a 26/8 for 300.00, then you still need 500.00 for a rebuild. At that point, I would suggest you consider a turbo with more future potential for upgrades such as the Vitesse. If not, just live what you have until you need to rebuild or replace your existing turbo.
Good luck in what ever you decide.
