Running Lean...don't know why
I just installed a fuel pressure gauge at the end of the fuel rail to get a better understanding of why I am running lean per my narrow band A/F gauge. Using Clarks guidance here are my numbers.
Jumpered: 37.5 psi
Idle: 31.5 psi
20-min leak down: 35 psi (40-minutes I am at 25 psi)
The first two numbers seem spot on which may explain running lean but the leak down is wicked slow going down to the 14.5 psi as it should be. I was hoping it was a fuel pump, filter (pre and post) causing the lean reading, but the fuel pressure is where it should be.
I am trying to track down a known good DME locally to see if that is the problem, but for now I am stumped.
Postnotes: injectors were recently rebuilt and matched, the o2 sensor is new, the DME relay is new, the A/F gauge reads a normal when car is first started, but goes way lean then off the gauge (literally) after a couple of minutes. Car is very sluggish upon acceleration.
Jumpered: 37.5 psi
Idle: 31.5 psi
I have not. From everything I have read, a faulty FPR causes the engine to run rich, not lean. I suppose it would not hurt to replace.
Update (well not really. nothing changed. just an observation). I just went for a spin, no faster than 3rd. I was running lean, stopped and looked at the fuel pressure gauge and it was reading 30 psi while the AF gauge said way lean (only one red dask illuminated.) WTF!!!!
Damit this is frustrating.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Must be a narrow band O2 sensor and the old arc LED meter…
Chances are that you are not running lean – the narrow band O2 sensors will get non linear as they gets too hot. Then it won’t produce any meaningful readings.
What are your other mods?
Chris White
Chris White
Chris, you got the gauge pegged. It is an Autometer narrow A/F gauge (carbon for what it is worth, zero!). Regarding mods / specifics.
Rebuilt and matched OEM injectors
Ported/polished/o-ringed Pauerhaus head
WFHG
Billet Diverter valve
Tial 38 WG
Weltmeister chips (both DME and KLR)
New bosch fuel filter
Replaced all vaccum lines (LR)
Stock turbo and exhaust
Nothing fancy.
WFHG
Tial 38 WG
Nothing fancy.
One of the most important things on any 951 is the vac/boost signal to the fuel pressure regulator.
Since you have just changed yours, double check that you have a good signal to the regulator, and THAT IS NOT OPEN OR DISCONNECTED ANYWHERE DOWNSTREAM.
You can easily blow a 951 headgasket under boost if this little plastic K-mart tube pops off.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
WFHG
Tial 38 WG
Nothing fancy.
WFHG
Tial 38 WG
Nothing fancy.
If you are runngin boost any higher than stock you will be overheatign teh narrowband adn it won't help you.
Chris
UAE Rennlist Ambassador
WFHG
Tial 38 WG
Nothing fancy.
WFHG
Tial 38 WG
Nothing fancy.
Get to he dyno, see what the AFR is really like.
Also, i heard welt. chips require the 3 bar FPR to run properly, on stock engines.
My $0.02
So I am looking at an adjustable fuel regulator, piggy back and wideband? Would a piggy back system take the place of a remotely adjustable fuel regulator (not the regulator itself, just the remote part)?
Drive-by provocation guy
Short of getting a WB gauge, what can I do to ensure I am not running lean? Would an emissions test at the local Goodyear be worth it?
