Installing Delphi injectors (Resistors?)
Legend Killer
I am going to install some new Delphi 55# injectors. These injectors are low impedance (coil resistance = 2 ohms).
I have searched and my head is still spinning from the "do i need resistors or not" threads. But I would like a final definitve answer from anyone who knows for sure wether I will need ballast resitors or not.
I dont want speculation I want a known answer and woul dlove to hear from anyone who has installed the same injectors.
Do you have a part number and/or can you post a picture. I believe these are the same injectors I ran for years (without resistors) but can't be sure without a part #.
I see. Those are not the ones I used -- mine were the 50# injectors listed directly above the one's you bought. The 50# injectors are listed as 12 ohms, and worked fine for years with no resistors. The 55# injecotrs you bought are listed as 2 ohms, so...
My old injectors are just sitting in a box, so if you want to return yours and use mine to be sure, I'll sell em for a song...
Legend Killer
so maybe I bought the wrong impedance level? I wonder if I can still retrun them? I will take you up on your offer if I can get racetronix to take them back. Thanks.
Putting resistors in is not nearly as big a deal as it's sometimes made out to be.
Here's a good thread with pics of a couple of different installs Click Here
Agreed -- not hard. I'm sure you can use those injectors. I made a plug n' play module out of a little project box. Made a jumper plug too for those days when the resistors are not needed.
Haha -- I can help if you need it -- it's easy though -- just go to fry's and get a small metal project box, a disk drive power supply harness, some seat sink goo, and some little nuts and bolts, and a grommet. Fry's did not have the right resistors though, so you probably have to go to Jameco in Belmont or go mail order for them...
Andial951, I'll make you one since I am about to make myself one. I thnk I even have enough resistors. PM me if you want one. I'll check pricing for every thing this week.
Legend Killer
well as you can see this thread is about 1 year old and I had been running the car without resistors till now. I just figured I was running on borrowed time or maybe the need for resistors is just another urban legend.....
